Rough engine idle and hesitation; Need some expert help
Topic Started: Jul 14 2014, 07:08 PM (2,160 Views)
roxann
Sheananigans, I have the same problem with my 87 Chevy Sprint. It has just recently started the hesitation, intermittent.... like two to three days, off and on.... However, when it rains, it runs like a champ. WTH it that about? Electrical "connection"? I'm in hopes that you have found your solution. I have replaced all of my filters, done a tune-up, still have no results worth posting. UUUGH I am at my wits end. I have owned this car for over 15 years, NEVER had this much trouble.
P_44_12
Sounds like you need a new coil
2000Firefly1.3L
ignition system issue
econoboxer
I am the one on the left.
many of those new 02 sensors are crap- not any better than what you replaced. <br />In this instance- for drive-ability, get the oem recommended, not the parts store generic.<br />Been there- done that. Just my $0.02
sheananigans
Hmm. It seems I will have to try replacing my MAP sensor and o2 sensor. Does anyone have a spare map I could buy off of them? The local yard is pretty far away from here. Also where would you recommend buying the OEM o2 sensor? The one I have now is a duralast piece of crap
sheananigans
2000Firefly1.3L
Jul 28 2014, 12:46 AM
Why do you believe is specifically ignition ? I just want to know to clarify
sheananigans
Looks like from what I can find on rock auto the OEM o2 sensor is the denso Part # 2344049
Can someone confirm fo me? Would one of the cheaper equivalents work from rock auto? I think not I just want to check to make sure. It needs to be the o2 sensor for calf. Advanced emissions.
