1991 Metro Engine Harness Connections
Topic Started: Jul 19 2014, 01:53 AM (455 Views)
irishman72
Howdy. I pulled my engine out for a rebuild over a year ago and have it back in now. Unfortunately I lost my notes about what wires go where and would appreciate any help you might offer.
The numbered tags you see on some of them were from a head gasket replacement a few years ago. They worked great! Too bad I cleaned them all off the engine side.
1991 base Metro with standard transmission.
Thanks in advance.
Matt
1 --
2 --
3 --
4 --
5 -- Alternator hot wire
6 -- Alternator plug
7 --
8 --
9 --
10 -- Green plug @ driver's side rear of throttle body
11 -- Blue plug @ driver's side rear of throttle body
12 -- Passenger side top of throttle body
13 -- Throttle position sensor
14 -- MAP sensor
15 -- O2 Sensor
16 -- AC Fan?
UncleBranton
1. Distributor
2. ??
3.
5. :thumb
6. :thumb
8. ground
10. :thumb
11. air
12. :thumb map
15. O2
16. oil
I don't see your starter wires so I hope you know them.
This was an automatic so I think plug two might be your shift light.
It pretty hard to mix most of these wires. Good Luck!!
irishman72
Awesome! Thanks!
irishman72
Okay, got it all together. New info:
#2 goes to a plug near the EGR valve. Found the shift indicator further down the harness.
My #7 was black with a yellow stripe and goes to the starter solenoid.
Your (UncleBranton) #7 above is yellow with a black stripe and goes to a sensor on the intake manifold.
I distinctly remember this not being hooked up before on mine. What is it? Where does that yellow/black wire come from.
Off to hook up vacuum lines! Thanks again for the help!
geogonfa
yellow with a black stripe and goes to a sensor on the intake manifold. that is the a/c cut off switch if the coolant gets too hot...
a/c will not work properly if this wire is not hooked up...
:type
