| Air Bag Light; Light Go's On/Off While Driving | |
| Tweet Topic Started: Jul 21 2014, 12:15 PM (352 Views) | |
| GeoJoe1995 | Jul 21 2014, 12:15 PM Post #1 |
1995 Geo Metro Air Bag Light does the standard "flash" once cranked, but then stays on while driving until I hit brake peddle, then it goes off, but comes back on once I start to accelerate?? Any help is greatly appreciated. Just read a post about two yellow fuses near firewall, will check, maybe that's the culprit. Thanks in advance! |
| idmetro | Jul 21 2014, 12:51 PM Post #2 |
Haven't had that experience on the later models but my 92 vert had an airbag fuse (in a flourescent yellow holder, connected to bright yellow wires) conveniently located where my dainty size 13 foot would periodically dislodge it, causing the same symptoms you describe. On the 92 when you turned the key on the airbag system did a self diagnostic (light flashed 5-7 times and then went out if all was well). Good Luck! |
7:27 PM Jul 10
