Need Heater HELP!
Topic Started: Jul 21 2014, 06:55 PM (400 Views)
tac2013
Howdy Guys.....well now heater stopped working. I did a resistance test on heater motor after checking the 20 amp fuse under hood and all 4 of the 20 amp fuses under dash. The resistance was a little off on 2 of the test connections but good on other two.
what slays me is there is no power to the blower plug. Got any ideals of what is going on here?
Is there any need to remove the instrument part of the dash, you know that part with all the slider switches.
Thanks Guys
Patrick
Skagit County, Wa.
JellyBeanDriver
If it doesn't work at any speed, likely the blower switch has broken apart. A zip tie will keep it held back together and likely fix it for you. Did for me so long ago I don't remember when I did it.
Edited by JellyBeanDriver, Jul 21 2014, 11:02 PM.
Stiffchezze
Sir Metrologist
The dis-assembly is a little different but this should get you there. 99.9% chance this is your problem.
Here ya go! :thumb
Link--->Fan switch repair
tac2013
THANKS Guys!...as usual you came thru like storm troopers.....I will tear into dash controls and see if I can use this info and pictures to fix it.
Much Obliged
Patrick
Skagit County, Wa.
