| ignition cylinder | |
| Tweet Topic Started: Jul 26 2014, 08:46 PM (456 Views) | |
| Potter | Jul 26 2014, 08:46 PM Post #1 |
Col. Potter
OK I give up I've looked for the little button that takes the ignition cylinder out. How do you pull this stinker out? |
| dayle1960 | Jul 26 2014, 09:09 PM Post #2 |
Put the key in, turn key, twist key/cylinder? Button might be on the bottom of cylinder? Sledgehammer will work when nothing else will!! |
| geogonfa | Jul 26 2014, 09:17 PM Post #3 |
The ignition key cylinder has to be drilled out...it has 2-3 blind pins holding it in place, depending on the year... |
| pdqrunner | Jul 26 2014, 09:39 PM Post #4 |
Any pics out there on this subject? I have half a key in my ignition and it would be nice to get it out without spending $150.00 for a locksmith. |
| Potter | Jul 26 2014, 10:33 PM Post #5 |
Col. Potter
Time to break out the drill then |
| 3cyltom | Jul 26 2014, 10:38 PM Post #6 |
Yep already did this. 3 lil bitty pins to drill out. Then 2 cone shape bolts need to be dremmel'd out to make a slot for a screw driver. Takes the whole thing off. |
| Old Man | Jul 27 2014, 01:43 AM Post #7 |
Here is a "How To": http://geometroforum.com/topic/4912705/1/ |
| idmetro | Jul 27 2014, 12:13 PM Post #8 |
Just take the entire assembly out of the car and to the locksmith - last time I had one done it was under $50... |
7:27 PM Jul 10
