FI fuse under hood causing drain, now what?
Topic Started: Aug 2 2014, 05:32 PM (390 Views)
3Banger91
Found the circuit that was draining the battery, its the 15 amp fuse under the hood for the FI. Is this a common source of shorts and drains and how hard is it to fix? I was taking the fuse box off when it started raining again!! Can't wait to get to the bottom of this problem, its gotta be simple to fix.
freegeo
Have you checked the bottom of the FI relay on the fuse block for corrosion?
3Banger91
Yes, but not thoroughly, the rains won't stop. I will get on it in the morning. Is it true 91 Geo's don't have EGR so the wiring harness by the alternator under the intake wouldn't cause a short would it? Do the white and red wire running from the FI fuse run the same way as EGR cars?
