intermittent problem, need help; Very intermittent problem no codes
Topic Started: Aug 8 2014, 07:01 AM (958 Views)
MightyMonte88
The cat was removed by the PO, just straight pipe in its place.
ptcapboy
you might want to pull off the valve cover and look at the rocker arms and lifters-mine are always acting up-a poor design
Electrical problems can manifest in many different ways. I'm interested to see if your no MIL lamp problem fixes your driveability problem. I would certainly refresh the main ground connections, i think the key one is under the throttle body, same as a three cylinder.
Once you get MIL going, if it doesn't blink out a code leading you directly to your problem, I would look into the fuel injector. Is it getting good power, and is it spraying a nice cone of mist.
