| no start; fuel | |
| Tweet Topic Started: Aug 9 2014, 12:23 PM (376 Views) | |
| crazywolf | Aug 9 2014, 12:23 PM Post #1 |
hae 98 chevy metro ran great was driving and stoped on me got it home started then wouldn't start the next day not getting fuel to the injectors will start with carb spray then die out i put in a different fuel pump not the prob hooked up both fuel put out of the gas tank they both run fine hooked up a fuel pump out of the tank and still wont start i can get fuel to the injectors just wont start can anyone help |
| Metromightymouse | Aug 9 2014, 12:56 PM Post #2 |
Is the injector spraying fuel? |
| crazywolf | Aug 9 2014, 01:13 PM Post #3 |
ok update even though i got no reply's i put old fuel pump back in have fuel to motor started right up but i can't trust this fix becouse it stopped running on me while driving and would not start back up when i towed it home need help thanks |
| crazywolf | Aug 9 2014, 01:14 PM Post #4 |
yes getting fuel through the injectors runs now but for how long |
| crazywolf | Aug 9 2014, 01:14 PM Post #5 |
sorry about the no replys lol just a headach |
| Metromightymouse | Aug 9 2014, 01:15 PM Post #6 |
Check the wiring to the injector, it sometimes breaks and creates an intermittent problem. |
| crazywolf | Aug 9 2014, 01:18 PM Post #7 |
will have to do that best done while its running right |
| crazywolf | Aug 9 2014, 01:19 PM Post #8 |
just can't fig out y other fuel pump will come on and not send fuel with supply line off |
| crazywolf | Aug 9 2014, 02:47 PM Post #9 |
ok all back together and runs at normal temp checked fuel injector wire looked ok disconnected the injector wires all look good plugged them back in ran fine so maybe just a bad conection hope so will post more when wife gets home and i can drive it more than 2 miles time to put a/c pump on old one went bad will be nice to have a/c again |
3:50 AM Jul 11
