cig lighter at 14 volts? is that right?
Topic Started: Aug 9 2014, 04:29 PM (323 Views)
geopanda
Do it Yourselfer
Ok I have my cigarette lighter in my 91 3/auto and if i use it i blow the fuse. Regardless of amps it blows. I even tried a 30 amp and it blows if i try and use the lighter. I can use a 12 volt charger and it won't blow. I tested the voltage today with car running and got 14 volts all around. Shouldn't it say 12??? Any help appreciated.
scott_382
Educated guess............If nothing else is blowing out then you probably have a short in the lighter. Are you using the lighter it self or some other plug in accessory.
14 volts with engine running is normal.
geopanda
Do it Yourselfer
My car came with a lighter, it trips it. Got a different lighter from a geo parts car / trips it. Any 12 volt accessory will not trip it.
fireflyin
if your accessory wont trip the fuse then its your whole cig lighter that's tripping it happen too me intel i replaced my fixed the issue all together
if u replace the () piece where lighter plugs in with a new one it will work fixed my issue when i had the same thing happen
geopanda
Do it Yourselfer
Yahh I looked at the wiring for it untouched. Read 0 volts with car off. The lighter is stuck in the plastic part. How do I get it out? I tried twisting / pulling to no avail.
fireflyin
back of your cig lighter that twists off and then it pulls out after u got back piece off depending on how tight it is mite need little pliers or to undo two screws at top by radio two at bottom by cup holder / cig lighter and one by steering column to remove plastic piece order to get better grip at it
