piston removal
Topic Started: Aug 11 2014, 06:06 PM (294 Views)
sheananigans
I know you can get the pistons out through the top of the block with the head off, but has anyone tried taking them our through the oil pan side? I'm sure they would come out but what I want to know is can it be done without removing the crank?
High MX
Nope; won't happen. The crank journals bearing blocks are in the way.
Edited by High MX, Aug 11 2014, 06:10 PM.
sheananigans
Well thank you kindly. I guess I'll have to get a head gasket and new head bolts!
perfesser
I took a piston out through the oil pan last winter, but most of it was already in it when I took the pan off! :O :O
