| Geo Metro "Italian Tuneup" - It Worked!; 1992 was using some oil. | |
| Tweet Topic Started: Aug 12 2014, 11:00 AM (1,886 Views) | |
| rmcelwee | Aug 13 2014, 06:29 PM Post #16 |
You can assume that I was completely lost on the point he was trying to make as well. Anyway, if we are calling going into full engine braking an "Italian Tuneup" then that is what I use to break in a new engine. Edited by rmcelwee, Aug 13 2014, 06:31 PM.
| Johnny Mullet | Aug 13 2014, 07:26 PM Post #17 |
This procedure is also used to seat rings after a rebuild. |
| myredvert | Aug 13 2014, 07:43 PM Post #18 |
Exactly. To my knowledge the original Ferrari version of the Italian Tune Up was just a high rpm loaded run(s) to clear carbon build up, without the engine braking/ring seating portion which is a common break in procedure. But if it helps clear up the problem and reduce oil consumption, then cool beans!
Edited by myredvert, Aug 13 2014, 07:45 PM.
| cwatkin | Aug 15 2014, 08:50 PM Post #19 |
I found this article: http://www.mototuneusa.com/break_in_secrets.htm This break break in looks similar to the ring freeing method I used. My only guess is that if the rings aren't too stuck, this can bust them loose. Now I know this didn't work on the POS G10 I had in my 1994 to start with. Once I got a replacement engine, I used to just floor it and watch the smoke come pouring out the back. I did this one time and pulled into the next gas station and added a quart of oil without even looking. I then checked and needed to add even more oil! That engine was the oil farting champion of all time! Conor |
3:49 AM Jul 11
