pulley question
Topic Started: Aug 15 2014, 12:42 PM (290 Views)
nickb803
NickB803
Got a 94 1.0 metro. Just got the srd double underdrive pulley for my ride. Anyone have part numbers for the 3 rib belts? Prefer gatorback belts if possible. Apparently the set I bought is 4 rib and my water pump pulley is 3 rib. .... Thanks.
rv93
how much smaller is this pulley compared to stock? you may still be able to use factory sized belts, or you may need to go just a little shorter.
nickb803
NickB803
I think I got the belt size calculated out. Srd decided to send me a pulley that has the keyway slot not correctly cut. So I shall file it until it fits like a glove.
