| Crankshaft Bolt; Crankshaft Bolt won't come off | |
| Tweet Topic Started: Aug 24 2014, 02:52 PM (353 Views) | |
| 3 Pot | Aug 24 2014, 02:52 PM Post #1 |
3 Pot
Hello All, Working on my 93 3/5 and having a time getting off the Crankshaft Bolt. The forum had some great ideas and I tried my impact driver as per Johnny Mullet's directions to no avail. My little compressor goes up to 120 PSI and I thought that would be enough. Then tried the breaker bar with the starter motor method and still not budging. Any thoughts on method 3? 3 Pot |
| Justahoby | Aug 24 2014, 03:02 PM Post #2 |
Unqualified informant
Got a propane torch? Warm up the bolt to soften the factory thread locker.. Take your time. If you did not plan on changing your seal, well I would especially if you warm it up .. I had a beast of a time doing my first one.Cheater bar on a breaker bar. Motor out of the car.. |
| nickb803 | Aug 24 2014, 03:06 PM Post #3 |
NickB803
Stick a screwdriver in the back of the flywheel. That will prevent the crank from turning allowing you to break it free. |
| Memphis metro | Aug 24 2014, 03:09 PM Post #4 |
Cheater pipe extension on a half inch drive ratchet and six point socket with flywheel secured. |
| 3 Pot | Aug 24 2014, 04:06 PM Post #5 |
3 Pot
I tried Big Rhino's breaker bar method with heat and finally with a mighty CRACK!!! the bolt let loose! And then it just turns by hand and all after that. I was sure it would break off but thankfully all is intact. Now to finish the oil seal and pan gasket. I will use gasket maker as I heard that is more reliable. Thanks for the help! 3 Pot |
| nickb803 | Aug 24 2014, 04:15 PM Post #6 |
NickB803
Yep gasket maker. Stay away from cork lol |
| ptcapboy | Aug 24 2014, 04:46 PM Post #7 |
when I tried rtv it leaked like a sieve-i'm not very good at it-I'm a cork man |
| Memphis metro | Aug 24 2014, 05:46 PM Post #8 |
3:48 AM Jul 11
