header 1.3L 16valve?
Topic Started: Aug 28 2014, 01:33 AM (324 Views)
fireflyin
Suzuki racing said basically i gotta extend my o2 sensor wires so it reaches farther back since its like a long tube header design is there anyway i can find a o2 sensor wire extenders? and would it make the car run leaner or anything since its gotta use more resistant? since its a longer wire?
fireflyin
Just use wire of the same size and it would be better to solder them in instead of using crimps. The amount of added resistance is going to be tiny for the amount of wire you are adding so there should be no change to your AF ratio.
fireflyin
don't they sell wire extenders for them cars? idk hate to have to clip my harness
You wouldn't be clipping your harness, you should splice into the O2 sensor harness, then your cars factory harness will remain unaltered. The last O2 sensor I bought had really long wires that you cut to length and inserted into the connector where it clamped them in and made the contacts. Maybe just a new O2 sensor would solve your problem.
fireflyin
i just replace a new o2 sensor lol don't need another one aha i'll try stores n see what they have
