| New garage / workshop; shell is up, now the work begins | |
| Tweet Topic Started: Aug 30 2014, 10:42 AM (1,422 Views) | |
| Car Nut | Aug 30 2014, 09:02 PM Post #16 |
Sir, you sound like a very wise man.
| TimmyD | Aug 30 2014, 10:13 PM Post #17 |
A Metro Driver
How much? I'm contemplating doing a 2nd mortgage on the house to consolidate, remodel the kitchen and build a 1.5 car garage w/lift. Edited by TimmyD, Aug 30 2014, 10:13 PM.
| Bjetmech | Aug 30 2014, 11:56 PM Post #18 |
Very nice!!!
| Car Nut | Aug 31 2014, 02:50 AM Post #19 |
Don't do just a 1 1/2 garage. Minimum 2 car. Won't cost that much more. Always build as big as you can afford. I had a 3 1/2 car years ago & it wasn't enough. Filled it up with junk too quickly. Loved being a horder too much.
| Mythstae | Aug 31 2014, 03:01 AM Post #20 |
Very nice, Joe!
| geogonfa | Aug 31 2014, 08:40 AM Post #21 |
Sweet...
| rmcelwee | Aug 31 2014, 11:09 AM Post #22 |
Looks great! Are you going to put any insulation in there? |
| Old Man | Aug 31 2014, 01:10 PM Post #23 |
Yes. for the ceiling: Havent looked for sure but I think a combination of tyvek and r18 held up with wires for the ceiling. Still considering radiant sheet and sprayed in--but so far the simplest seems to be tyvek and insulation batts.----all held up with monel wire. walls: 2x6 studding between the steel and tyvek and r18 batts with 1/2 plywood sheathing suggestions?? |
| rmcelwee | Aug 31 2014, 02:12 PM Post #24 |
I blew insulation in the attic in my shop and put the pink panther stuff in between the studs. I covered everything, even the ceiling, with OSB (you will be amazed what you can find on craigslist at a discount). I put 6 sheets of 4x8 pegboard on 1x2 framing to hang tools and stuff. If I had it to do all over again I might (this would be VERY expensive I think) consider using slat board instead of OSB. I do not know how cheap I could get it but it would be one hell of a solution. It has been a while since I posted this. Maybe someone will enjoy it: |
| Rondawg | Aug 31 2014, 09:41 PM Post #25 |
Very nice! |
9:27 AM Jul 11
