| Motor mounts?; or trans mounts? | |
| Tweet Topic Started: Aug 30 2014, 06:44 PM (609 Views) | |
| Tdallenbach | Aug 30 2014, 06:44 PM Post #1 |
In my 1995 Chevy metro 4 dr 1.3L 5spd, Accelerating up to freeway speeds if i lift off the gas too fast i get a jerking motion which i believe is the motor mounts. Rock Auto has motor mounts available to me is it worth it to replace all the mounts(2 engine and 1 trans)? Or is there a way for me to test which mount is causing the jerking motion? -edit- Edited by Tdallenbach, Aug 31 2014, 12:16 AM.
| 2000Firefly1.3L | Aug 31 2014, 10:55 AM Post #2 |
It is anything in the car that absorbs energy in the driveline. It could be the springs in the clutch, engine mounts. What I did was remove all my mounts and fill them with pourable urethane kit - which helped. http://www.energysuspensionparts.com/proddetail.asp?prod=DIYMMI However even with stiff mounts there is still jerking. My video ; https://www.youtube.com/watch?v=sMpbAGjI1aQ I have still to upgrade to a performance clutch but I'm pretty sure the pulsing is the springs absorbing and releasing energy. |
| Tdallenbach | Aug 31 2014, 07:10 PM Post #3 |
my clutch literally just exploded ha.. in the process of tearing the trans out right now. May just try to replace them as they are only $50 for all 3 and will have the bolts removed anyways i will further inspected them when i get closer |
| Bad Bent | Aug 31 2014, 10:02 PM Post #4 |
Good luck with that clutch. Here's another DIY motor mount thread: http://importnut.net/motormount.htm |
| Tdallenbach | Sep 1 2014, 01:19 AM Post #5 |
thanks bad bent i will give the DIY mounts a shot! I need to save a few bucks with the clutch problems |
3:48 AM Jul 11
