california cat vs standard
Topic Started: Sep 10 2014, 05:55 PM (844 Views)
mirad318
So I failed my inspection by 20ppm on hydrocarbons for Tx. Replaced all ignition components, gas filter, clean oil. Engine is newly built so not using oil.
Last part is catalytic converter.
Will a California approved cat be better in the emissions than standard? Im assuming yes. Any ideas?
Thanks in advance.
David95237
Just add some e85. I just had one that wouldn't pass by 100 points. 2 gallons of e85 and the number came down about 120 points.
Justahoby
Unqualified informant
that works, knew someont that dumped a pint of touline in there, but e85 is cheap :)
mirad318
Thanks I will try the E 85
econoboxer
I am the one on the left.
to answer your question- no- the CA cat isn't any better- just been through more rigorous testing and certifications.
We used to use rubbing alcohol from the $ store.
:gp
I've added Coleman Camping Fluid instead of Seafoam to clean the TB. My lawnmower likes it.
t3ragtop
i used mothballs,
made tree huggers happy.
you should try it.
the cedar scent,
makes them wear smiles.
silly tree huggers.
i hope you appreciate my haiku. ;) i might compose all of my posts in that format. :P
Edited by t3ragtop, Sep 17 2014, 06:06 PM.
t3ragtop
Sep 17 2014, 06:04 PM
i used mothballs,
you should try it.
the cedar scent,
silly tree huggers.
Dang! You are a poet, and we didn't even know it!
robertino
There is a chemical that I used twice now and passed both times so I'm going to recommend that you get it and follow the instructions precisely.
http://www.autozone.com/autozone/accessories/CRC-12-oz-Guaranteed-to-Pass-complete-fuel-system-cleaner/_/N-255s?itemIdentifier=128434
As far as the Cat ....we pay extra for that stupid CARB sticker, so Cali can make some money !
Edited by robertino, Sep 18 2014, 11:19 PM.
