Vert Exhaust
Topic Started: Dec 15 2014, 05:48 PM (404 Views)
tommer2
Help me out guys. Is the exhaust pipe from the cat down to the resonator a pipe within a pipe? I have a rattle that is driving me nuts. Could it be double pipes in the resonator? The resonator is about six months old. That's why I replaced the resonator because of a rattle before. I didn't have any rattles until now. When I get under the car and bang up on the resonator it sounds like a weld broke or something. Thinking about cutting out the resonator and replacing a piece of pipe. Think it would be to noisy? How about some ideas? Thanks!!
t3ragtop
to meet federal standards, the pipe from the manifold to the catalytic converter is double walled stainless alloy mandated to last at least 5 years in use.
i routinely replace the entire exhaust system from the flange at the exhaust manifold throughout and to the rear with 2" aluminized mill run steel electro-seamed pipe bent to match the oem pipes.
the exhaust shop i use charges me under $200 for the work, all in. the engine runs better with the 2" exhaust and the aluminized pipe lasts about 5 years in ohio winters with heavily salted roads.
Oddmodman
One idea is to replace the resonator with a like-sized glass pack. Amounts to the same effect I believe, but more sturdy. You won't have that rattling.
