| TB rear studs...pressed or screwed? | |
| Tweet Topic Started: Jan 11 2015, 11:36 AM (628 Views) | |
| Robertfrank | Jan 11 2015, 11:36 AM Post #1 |
As the title states, i'm wondering if the rear throttle body studs that mount the TB to to intake are pressed in or screwed in? Whats the easiest way to remove them?? |
| Memphis metro | Jan 11 2015, 11:43 AM Post #2 |
Pretty sure they screw in like the front exhaust bolts do. Double nut them and screw them out. |
| geogonfa | Jan 11 2015, 12:08 PM Post #3 |
| Fubar007 | Jan 11 2015, 02:54 PM Post #4 |
You might want to give them a few taps with a nut on the threads to prevent damage to the threads. A bit of shock to a threaded stud breaks the set and helps the extraction. PB Blaster is my Friend
| sphenicie | Jan 12 2015, 08:16 AM Post #5 |
they screw in as previously mentioned. penetrating oil.....soak....heat.....vice grips as tight as possible. they are available at most any hardware store, in the section with the little drawers, m8x1.25 I believe. about $1 each. |
| Richard123vmt | Jan 15 2015, 07:40 PM Post #6 |
You need two nuts tightened against each other. Then use the wrench on the bottom one. Heat and liquid wrench may help get it out without damage. They have been together a long time. so take it easy.
Edited by Richard123vmt, Jan 15 2015, 07:42 PM.
7:57 PM Jul 10
