| mushy brakes | |
| Tweet Topic Started: Jan 27 2015, 06:40 PM (486 Views) | |
| kaveman91 | Jan 27 2015, 06:40 PM Post #1 |
Mushy brakes at the moment . I just replaced back brakes yesterday on 89 geo metreo lsi 4 door and couldn't remember if I bled them. bleed brakes and problem goes away or bigger trouble ahead ? willc. |
| Good bye | Jan 27 2015, 06:43 PM Post #2 |
You need to bleed if you replaced the wheel cylinders. If not then you need to adjust the new rear brakes. Maybe both. |
| myredvert | Jan 27 2015, 08:11 PM Post #3 |
![]() Seriously? You can't remember if you opened the bleeder screws and let it drip through a tube into a jar for a few hours, then put more brake fluid in the reservoir, or had someone repeatedly pumping the brakes while you talked to them while you opened/closed the bleeder screw and checked and filled the reservoir a few three times, or hooked up a vacuum bleeder to it and monitored/refilled the reservoir, and had a container full of old brake fluid to get rid of when you were done? ![]() Yes, you need to bleed them.
| Woodie | Jan 28 2015, 06:05 AM Post #4 |
Could be that they just need to adjust themselves. Also could be that the auto adjusters aren't any good, they strip out a lot. Try pulling your e-brake up about five clicks and see if they feel better. If so, then it's an adjustment problem. |
| owlafaye | Mar 21 2015, 01:13 PM Post #5 |
Dr. Cool
9:50 AM Jul 11
