| Full Battery Power, One Click, Won't Start | |
| Tweet Topic Started: Jan 30 2015, 06:33 PM (1,783 Views) | |
| myredvert | Feb 20 2015, 12:35 AM Post #31 |
The FSM battery check is located in Section 6D1, Battery. (link>>) Section 6D1, Battery check begins on page 4. As far as the required loads/durations, etc... The chart (figure 5) lists the appropriate minimum voltages from 9.6V @ 70 F to 8.5V @ 0 Degrees F |
| yiffzer | Feb 23 2015, 10:28 PM Post #32 |
Forgot His Manpurse
Returned Walmart EverStart battery, got $87 dollars back, including core charge. Bought Optima Red Top from AAP for $159.99 (warrantied from January 2015). Bought two brass tops for $7.00 total. Cleaned all grounds on the firewall, including motor wiper's (forgot that one). Cleaned grounds attached to the solenoid and alternator. Tightened ground to the alternator (it was loose). Brushwired exposed wires between starter and solenoid and all other cables to the battery. Pried back alternator to make belt tighter and to reduce squealing. Cleaned PCV valve because I smelled oil and saw oil residue in the air filter (could be why I had lower than average MPG). Cleaned Y tube connecting between the PCV valve and air cleaner housing (it was full of crud). Installed battery and lubricated bottom ends of the posts with vaseline to prevent corrosion. Tested battery at 12.6 volts. With full load (headlights, heater, domelight, headlights all on) and engine on, showed 13 volts which means the alternator is doing its job. Car started up so far three times without fail... with temps being 6 degrees this morning and later -4 degrees today. So we'll see how it goes from there. Total cost so far: $80.00~. Edited by yiffzer, Feb 23 2015, 10:28 PM.
| Woodie | Feb 24 2015, 06:04 AM Post #33 |
You should have been blaming the battery in the store, before you bought it, when you saw that it had a two year warranty. |
| yiffzer | Feb 24 2015, 08:17 AM Post #34 |
Forgot His Manpurse
I was only 11 months into the warranty! And I think it's pretty standard to have just 2 years warranty.
Edited by yiffzer, Feb 24 2015, 08:17 AM.
7:58 PM Jul 10
