| Stereo Upgrade, no power to unit | |
| Tweet Topic Started: Mar 14 2015, 01:40 AM (1,370 Views) | |
| Mythstae | Mar 14 2015, 11:11 PM Post #16 |
Thanks. Made that chart/diagram myself. ![]() I even re-drew the connector face and re-labeled it. ...I have very peculiar hobbies. ![]() If you can solder, I always recommend soldering and heat shrinking to crimping; but if you can't solder crimping is a step up from twist'n'tape. ![]() Also, make sure you don't shorten the wires too much when you try to repair them. If you try to repair it, and then I have to repair your repair... it could get difficult. You lose wire length every time. ![]() Well, welcome to the neighborhood! I need to put together another meet sometime, haven't had one in far too long!
| Car Nut | Mar 15 2015, 04:25 AM Post #17 |
Yeah, that's what I meant. Very tired when I posted that. I know yellow isn't correct for factory wiring. Point I was trying to make was refer to the FSM, not just guess. I just didn't do a very good job of it.
| Mythstae | Mar 15 2015, 05:09 AM Post #18 |
![]() Been there, done that! It's all good.
| elgecko | Mar 21 2015, 08:23 PM Post #19 |
I appreciate everyone's help with this but in the end I had to call in an expert. Luckily I have a good friend who is a savant and he took the time to correct the mess that the previous owner had created. The issue turned out to be the ignition power, not the ground. It looks like said previous owner had plans to swap out the radio but got confused and started cutting wires for whatever reason, then trying to paste it all back together. There was no right speaker, either. Anyways, as you can see from this super high-def photo everything is connected in a more logical manner (and soldered/shrink wrapped no less) and now I have music! Thanks again for the help!
7:58 PM Jul 10
