12" to 13" Lug Nuts
Topic Started: Mar 26 2015, 12:36 PM (464 Views)
Horn
http://www.brandsport.com/grla-71118.html
There you go. These are for Gorilla 71118
If you buy 16 (you get a small discount) and with small shipping it is under $20!
Just a heads up.
Thart10
Check local Tire Stores that deal with custom Rims. What you are looking for is 10mm x 1.25 "Bulge Nuts".
I'm been running them for two years with some Alloy Rims at 45 Ft lbs Torque. Before that I had some "Steelies" at Stock Torque.
EDIT: I checked out the ones above. Unless you needed them yesterday, the shipping isn't that bad. I can get a whole set of 16 for $19.39, or $1.1212 Each. Not bad.
Edited by Thart10, Apr 2 2015, 04:16 AM.
