Headlights; Straight confusion
Topic Started: Apr 6 2015, 04:13 PM (653 Views)
TheNewGuy
I got a 96 metro with headlight problems. DRL's come on but when i turn the headlights on..... NOTHING! The park lights come on but no headlights. If you pull the high beam lever towards you the high beams come on but when you flip them forward then nothing!! Ive changed out the relays and all fuses but still no worky?! Any ideas?
Mythstae
Read this: How To - Fixing headlights; Repairing electrical circuit
I like to do it the way GeoRating did it; here is a link to those posts only: How To - Fixing headlights; GeoRating Style
ptcapboy
I had the exact same problem and the Geo Rating fix worked for me
TheNewGuy
Thanks Mythstae! I have been doing further digging on the net any just found a topic similar to the one you just found. As soon as I get home I will know that i can fix this little problem.
TheNewGuy
The further i keep looking it seems like this is a comon problem. Thanks again for all the help.
Mythstae
:thumb
Make sure that you get a tab terminal that has the shape to click in to the plug.
My first one didn't, the wire slipped most of the way off, and burnt.
The second one I did, I used a better connector, and I think the metal was thicker, made for thicker wire, etc.
So I doubled the wire over, soldered it inside the terminal under the crimp, heat shrinked over it, and then had to FORCE the terminal inside the plug with a pair of pliers. At least I know now it won't come out on accident again...
TheNewGuy
Apr 6 2015, 05:16 PM
Probably the most common problem Metros have.
