| routing wiring | |
| Tweet Topic Started: Apr 10 2015, 06:54 AM (350 Views) | |
| PB56 | Apr 10 2015, 06:54 AM Post #1 |
Hey..I just got a mpguino and have the wiring from the engine into the cab through the door...I am asking if anyone has a good route out could let me know the best way to get the wires into the cab the most discrete way...would prefer not to drill but would if there is a good way to go about it...thanks |
| Stiffchezze | Apr 10 2015, 08:04 AM Post #2 |
Sir Metrologist
On both sides of the engine compartment, there are large rubber grommets where the main trunk harness come into the car through the fire wall. On the drivers side it is just under the brake booster; on the passenger side, just above the A/C lines. It is very easy to come though here. I like to take a piece of stiff wire (think coat hanger) and put a small hole in the grommet just under the harness. Be very careful not to nick the main trunk harness when you come through. Also do not "go around" the grommet. Worked on a car once that some idiot ran an 8 gauge wire with no fuse around a main trunk harness grommet. ![]() Sure enough after a few miles the sheet metal cut into the wire.....
| PB56 | Apr 10 2015, 11:41 AM Post #3 |
Alright cool thanks...and I will for sure not go around the grommet |
7:53 PM Jul 10
