| no headlights on vert; need help | |
| Tweet Topic Started: Apr 12 2015, 03:10 PM (342 Views) | |
| ncdad1969 | Apr 12 2015, 03:10 PM Post #1 |
1991 convertible metro. Headlights stopped working last night. Turn signals, brake, running lights all work. Checked fuses...they were okay. Checked spot on fuse box where wiring connects...no burns. Thinking its either the push button head light switch or the high/ low -turn signal switch. Any suggestions, tips, fixes or location to buy these parts would be greatly appreciated!!! |
| myredvert | Apr 12 2015, 03:47 PM Post #2 |
When mine stopped working for no apparent reason, I sprayed contact cleaner inside the base of the stalk the best I could, and actuated it several times and sprayed again. Did this for a few days and they started working again and have not quit again since. Yet. ![]() The contacts in switch can get pretty corroded. |
| t3ragtop | Apr 12 2015, 03:51 PM Post #3 |
check for a melted. burnt connector on the fuse block up under the dash. does the car have operational high beams? |
| ncdad1969 | Apr 12 2015, 04:06 PM Post #4 |
High beams only work when I pull the turn signsl switch back (pass lights). Otherwise no lows and no high beams. Check under the dash at the fuse panel ...no burnt connections. No burnt wires. Edited by ncdad1969, Apr 12 2015, 04:21 PM.
7:53 PM Jul 10
