Starter Motor - Repair, Replace?
Topic Started: Apr 12 2015, 03:32 PM (629 Views)
RedwoodGuy
I've owned my '91 Metro for 2 days and TWICE I have turned the key with no cranking. Battery has juice, horns and light work, small
"click" when the key is turned but no cranking.
1. First time it happened, I repeatedly turn the key back and forth and after a few minutes, it cranked and started.
2. Second time, no amount of key turning worked. I opened the hood, located the starter and "tapped" it several times with a stick/hammer. Then reached in, grabbed a short 2: wire that seems to go from solenoid to starter and wiggled it for good luck. Got in, it cranked and started.
Ok, I can't live with an unreliable starter. How difficult is it to replace this? Are the starter and solenoid separate items? Any tips?
RedwoodGuy
Your starter and solenoid are GOOD.
The 'short wire from the starter to solenoid' has a connector on the end of it. That connector get corroded. clean it.
metros are famous for ground connections getting corroded. polish the following connections: every end of every battery cable-bottom of TB has a couple of wires grounded to it. - distributor has a ground wire - coil has a ground wire - any other grund connection you can find----take them apart and polish them.
If you still have problems there is a 'bypass' system that works every time--I will see if I can find it for you.
EDIT:
Read this thread:
http://geometroforum.com/topic/4725121/1/
Edited by Old Man, Apr 12 2015, 04:27 PM.
Hanuman
cleaning grounds: http://geometroforum.com/topic/5720306/1/
starter theory 101: http://geometroforum.com/topic/5753206/1/#new
Edited by Hanuman, Apr 12 2015, 06:52 PM.
RedwoodGuy
Great information! Thank you all. I will follow the relay route. Is there s specific part number that people have used, of is it generic 30A relay?
