| Quick, easy, cheap fix for cloudy headlight lenses; Saw this online, tried it and made a little video.... | |
| Tweet Topic Started: Apr 26 2015, 11:32 PM (715 Views) | |
| Rondawg | Apr 26 2015, 11:32 PM Post #1 |
Dunno how long it will last but it worked like magic on my daughters Sebring.
| Old Man | Apr 26 2015, 11:44 PM Post #2 |
not working right for me. You say you saw it on utube--why not just post the utube site. |
| perfesser | Apr 26 2015, 11:54 PM Post #3 |
That is amazing! I will definitely keep this in mind! Unfortunately, the stuff dimming my Magnum's headlight is on the inside, so I need to take the headlight assembly apart. |
| Rondawg | Apr 26 2015, 11:57 PM Post #4 |
I don't think it was YouTube. I was on Facebook a few days ago, and a friend posted a link to something. Then when I watched that video, there were links to other ones. I think it was called "life hacks" or something like that. All sorts of weird Lil tricks, tips etc. Logged it in my mind.....today I was cleaning the garage and found what I needed and gave it a shot. You take some insect repellant with a high % of DEET. I used Backwoods Off with 25% DEET. Sprayed a good amount of it on a shop rag and wiped off the lens. I was amazed how quick and easy it cleared up. |
| fireflyin | Apr 27 2015, 12:05 AM Post #5 |
toothpaste is the cheapest and it works did both of my headlights what a difference |
| ptcapboy | Apr 27 2015, 12:17 AM Post #6 |
yeah the shop I drive by advertises $49.95 to clean two headlights so it's nice to be able to do it yourself and save big- |
| RAFA | Apr 27 2015, 06:07 PM Post #7 |
how do i play your little video? |
| Coche Blanco | Apr 27 2015, 06:26 PM Post #8 |
![]() Top picture is after, bottom picture is before. Coche Blanco does not suggest using this method. Edited by Coche Blanco, Apr 27 2015, 06:29 PM.
| Rondawg | Apr 27 2015, 07:37 PM Post #9 |
I've been reading up on it. Don't spray it directly on the lens....not good for paint if ya get some overspray. If you try it, spray it on your rag and then wipe the lens. Apparently the DEET actually melts a little of the plastic & that's how it cleans so well. Seems similar to a buffing technique, eats away the cloudy surface? |
| perfesser | Apr 27 2015, 09:14 PM Post #10 |
Why not? I like the idea of no more bugs on my headlights!
| Coche Blanco | Apr 27 2015, 09:19 PM Post #11 |
One of the few times I have actually chuckled because of a post on here. Lol |
| Stubby79 | Apr 29 2015, 09:38 AM Post #12 |
If it's melting the plastic, that's great...but I won't be putting any on my skin ever again! If it's just giving it a wet look, well, maybe some tire-shine will do the same? |
| Daox | Apr 29 2015, 10:05 AM Post #13 |
They key to making polished headlights last is to recoat them with a UV protectant. I did a write up, link below. The Metro headlights are still doing pretty good after about 6 months now. Without the UV protection, it can be as little as a month and they are cloudy again. Next time I do it, I'll add two or 3 coats of the urethane for longer protection. How to polish headlights so it lasts (re-adding UV protection) |
| nwgeo | Apr 29 2015, 10:17 AM Post #14 |
Just right clk on Rondawg's vid pic and open the link to photo bucket and you can watch it on there. I am going to try this with just regular Off if it has a little deet in it. Also thanks for the link on the UV protect |
7:53 PM Jul 10
