| Need pics of how to install brake pad clips; Redoing brakes on 63 Geo and too stupid to do it without a pic of how to install brake pad clips | |
| Tweet Topic Started: May 4 2015, 07:30 PM (1,027 Views) | |
| amyeel | May 4 2015, 07:30 PM Post #1 |
Okay am losing my mind trying to figure out how and where to install brake pad clips for my 1993 Geo metro...desperately need photos of such
Edited by amyeel, May 4 2015, 07:45 PM.
| amyeel | May 4 2015, 07:59 PM Post #2 |
I MEAN A 93, NOT A 63! DOH!! |
| RONNIEREDLINE | May 4 2015, 08:22 PM Post #3 |
METRO MAD MAN
a 1963 geo ?? hmmmm man thats just gotta be a collector car for sure ! ! ! wonder what the body style was? got a pics? i wanna buy it ! ! ! sight unseen. just kidding, hope someone posts a pic for you, if not i bet they can at least talk you through, as mullet man, he could tell you right away. |
| Mrbreeze | May 4 2015, 11:06 PM Post #4 |
Are you referring to the clips that sit on the top and bottom of the caliper mount where the pads ride? |
| solerpower | May 4 2015, 11:39 PM Post #5 |
The inside and outside clips attach to the square peg in the middle of the back of the brake pads. There is a little metal finger arm on each side that are in opposition to each other and the tension each one has on the square peg hold it on. If your using and old clip sometimes the bends in the little metal pieces are not at the right angle anymore. I use two small flat head screwdrivers and push down on top of opposing fingers at the same time (as close to the square peg as possible). The claw like one goes on the inside and fits into the hollow cavity of the brake piston. The wing shaped one goes on the outside and slides over the caliper fingers. There is also two side clips that have two 1 inch tabs that fold squeeze in when you fit them into the brake bracket. The tab on these that is bent in fit into the groove on the back of the brake pad by the little wings on the pads. Only one pad has these, pretty sure it is the inside one. I did this today, but I don't have any pictures. Hope this helps. |
| GeoMojoe | May 4 2015, 11:40 PM Post #6 |
Hope this helps. The drawing is drivers side.![]()
| brsja | May 5 2015, 12:18 AM Post #7 |
Of course you could always consider the brake upgrade...just a thought... |
| Mrbreeze | May 5 2015, 01:58 AM Post #8 |
Mine doesn't have #s 12,13,14,15,16.. Had the car since 99, just put second set of brakes on last summer.. And they work really good.. |
| dayle1960 | May 5 2015, 07:30 AM Post #9 |
Stick you foot out the door and stop the Pebbles and Bam-Bam way. Gheesh, these new metro owners need to learn what hardcore driving is all about. JK |
| amyeel | May 5 2015, 01:17 PM Post #10 |
Thanks a million everyone. All help is seriously appreciated. I've already worn out 2 boat anchors and a can filled with concrete pulling her down to a stop! Brakes will a new adventure. |
JK
9:50 AM Jul 11
