| All my lights pulse | |
| Tweet Topic Started: May 8 2015, 09:42 AM (528 Views) | |
| MetroKidd | May 8 2015, 09:42 AM Post #1 |
When I start the car and turn the lights on my lights pulse. Not just the head lights every friggn light tail lamps dash lights all of em. It dosent go away during driving. I need this fixed this is the 3rd alt. I've put on in in the last two years. What is wrong. Please help me out if you guys have any idea as to why is going on. |
| snowfish | May 8 2015, 11:24 AM Post #2 |
The usually suspect is grounds. Every ground needs to be clean, clean, clean. Especially the battery to engine ground. The alternator grounds through the lower bracket. That contact point needs to be clean. Even new batteries, and cables, need to be cleaned. All connections need to be shiny silver, or brass, color. No dull grey or brown.Get out your sandpaper and get cracking. Loosening, wiggling, and re-tightening doesn't cut it. They need to shine.
| MetroKidd | May 8 2015, 11:28 AM Post #3 |
I will give that a try and see how that works |
| Highwayman | May 8 2015, 12:06 PM Post #4 |
I have had the same problem for a couple of years. I added several more grounds, cleaned the grounds, replaced the alternator twice, I finally pulled the fuse box off the fender by the battery and cleaned the corrosion and connections on the bottom of the fuse relay box. I installed a new battery. I still have a tiny bit of a flicker but I have gotten used to it. Please let me know if you actually get it totally cured.
Edited by Highwayman, May 8 2015, 12:30 PM.
| t3ragtop | May 8 2015, 04:58 PM Post #5 |
it looks like you will be buying another alternator, too.
| Highwayman | May 9 2015, 11:56 AM Post #6 |
Ok i will replace it again. Thanks.... |
| dayle1960 | May 9 2015, 01:35 PM Post #7 |
If all the lights flicker then that leads me to think that ONE THING is the cause. Enough juice goes through a wire to cause something to heat up and the "blow a fuse", the wire (OE what ever the problem thing is) has enough time to cool down. Wash, rinse, repeat abfew times per second. Long way around the bard to say check the big ground wire that goes from the battery to the frame. Thatbwire might be cut, scored, burned, or whatever. Look at its entire length. Topside and bottomsixe for its entire length. Then check the contacts on that wire to make sure they are secure WITHOUT CORROSION. GOOD luck! Sorry for all of the grammatical errors.. Stupid fat thumbs. Edited by dayle1960, May 9 2015, 01:36 PM.
| Hanuman | May 9 2015, 06:28 PM Post #8 |
this post is on the right track, but its not the main ground to the tranny, ....maybe the frame. also as mentioned above.....look inside both of the fuse boxes......there may be a loose connection. inspect the relays also. when lights flicker....its always a loose connection. (oops, dayle didnt say the tranny ground) |
They need to shine.
7:53 PM Jul 10
