Bigger Rotors?
Topic Started: May 9 2015, 07:58 PM (456 Views)
Tubablake
Can you get bigger rotors?
Braking is poor due to such a small rotor size. I thought I had seen someone talking about it on here.
fireflyin
check your shoes and pads they mite be worn down cause my car stops quickly and i got oem rotors on
Tubablake
Hmm I'll take a look then
Mythstae
fireflyin
May 9 2015, 08:05 PM
Tubablake
May 9 2015, 08:13 PM
99 brakes are nothing like 91 brakes.
91 are hub-over-rotor and solid, unvented rotors.
If you want to upgrade to the vented style, you can either get 95+ brake components and use camber bolts, or, get the brake setup from a convertible OR Suzuki Swift in the older years, no camber bolts required.
This will, however, give you 12mm lug bolts - can't use the OEM 12" wheels anymore. Lug holes too small. Have to upgrade to 13" wheels, as well.
t3ragtop
the vert knuckle and brake upgrade gets you better wheel bearings, larger diameter ventilated rotors, and like melanie stated, 12mm lugs. use the vert drums, too.
i happen to have the brakes from my vert that were upgraded to the next level when i swapped in the twincam which is the 4 wheel disc gt brakes.
someone close to columbus ohio should buy these for their base model hatchback. ;)
Mythstae
Oh, yeah. Didn't mention the drums. :smackface
Tubablake
t3ragtop
May 9 2015, 08:49 PM
Are you going to palooza?
Mythstae
Tubablake
May 9 2015, 09:18 PM
t3ragtop
^o) Richard always goes to Geopalooza!
