| Which ones?; Bearings | |
| Tweet Topic Started: May 11 2015, 02:29 PM (609 Views) | |
| chavezja03 | May 11 2015, 02:29 PM Post #1 |
Needing a little help figuring out which bearings I need for the front inner. I see two different type for my year model, which is a '92. I'm wanting to change out all bearings on the front and rear. Thanks in advance. https://www.dropbox.com/s/kgxdtwqi6qtbgjy/Screenshot_2015-05-11-13-23-16.png?dl=0 |
| chavezja03 | May 11 2015, 02:34 PM Post #2 |
Apparently the rear ones have two different styles as well. One is much wider than the other. |
| snowfish | May 11 2015, 03:14 PM Post #3 |
For the front, you need 2 of the smaller ones. They're the same inner & outer. Be sure to grease them. The factory puts little, to no, grease in them. The rears take 2 different bearings. Example SKF 6204RSJ Rear Outer and SKF 6205RSJ Rear Inner. |
| chavezja03 | May 11 2015, 04:30 PM Post #4 |
what about for the rear? |
| sphenicie | May 12 2015, 08:18 AM Post #5 |
the "basic" numbers, which will work as a cross reference are; front= 2 required per side, four total; p/n= 107DD rear = one each per side four total; p/n= 204F & 205F |
| chavezja03 | May 27 2015, 02:06 PM Post #6 |
The bearings I got for the front are completely sealed. No need for greasing. Edited by Metromightymouse, May 27 2015, 02:10 PM.
| chavezja03 | May 27 2015, 02:09 PM Post #7 |
that didn't work like I thought it would. I thought my comment would have been outside the quote. oh well Fixed by your friendly neighborhood Metro Mighty Mouse Moderator.
Edited by Metromightymouse, May 27 2015, 02:11 PM.
| chavezja03 | May 27 2015, 02:51 PM Post #8 |
Thanks! |
| Woodie | May 28 2015, 04:06 AM Post #9 |
snowfish was saying that the sealed bearings don't have enough grease. They often fail after a year if you don't open them up and pack them full. |
9:50 AM Jul 11
