Mower mud racing!; Looks fun.
Topic Started: May 12 2015, 10:19 PM (1,750 Views)
cwatkin
https://www.youtube.com/watch?v=fh22csXOs9k
Stubby79
Probably too many laws, too much red tape to do that in north america.
Silver2K
Looks like fun. Doesn't look too dangerous, either. I assume they have removed the mower blade.
cwatkin
Sometimes I end up doing this unintentionally on my own property if I try to mow when it is too wet. :)
Yes, the entire mower deck appears to be missing on these mowers. For those who aren't familiar with riders, removing the deck is pretty simple. You pull 5-6 pins and the belt and the deck just slides out from under the mower. Sometimes I get high centered or hung on the deck while mowing in rough areas and raising the deck to its highest setting allows it to clear and then I can get unstuck pretty easy. Removing the deck completely would be even better for solving this issue.
Conor
cwatkin
Another issue that they must use cogged belts to get around is belt slip when wet. There is a low water crossing on my driveway. If I splash through it too fast on the rider, water gets up in the belt area and causes it to slip for a few seconds before it catches again. They OBVIOUSLY have some way to prevent this.
Conor
First result in https://duckduckgo.com/=american+lawn+mower+racing is 10 years strong: http://www.racingmower.net/
Posted Image Posted Image
Video: Kubota Supermodified Twin (ARMA) FXT (USLMRA) Racing Lawnmower
I think if it rained a little they might have a mud video. :dunno
cwatkin
How about this Honda? 130mph top speed! You could get the yard done in no time if you didn't kill yourself first!
http://www.rensselaerhonda.com/watch-a-lawn-mower-burn-rubber-in-belgium/
It seems this is the big thing in Europe for some reason.
Conor
bkelly
Gear Head
I built a pulling tractor about 10 years ago that was on a cub cadet frame.
