| ELECTRICAL PROBLEM!; CAR JUST SHUT DOWN. | |
| Tweet Topic Started: May 18 2015, 11:42 PM (561 Views) | |
| greenbean95 | May 18 2015, 11:42 PM Post #1 |
I NEED THE FORUMS HELP DIAGNOSING MY 1995 METRO 1. LTR 3 CYL. The car just stooped running and I noticed my dash check engine lights were out. I replaced the fuse and have my lights back but no spark from coil I saw this on the forum before. I have checked all relays and fuses and replaced my ignition module, changed out a pick up and tried a used coil. I also looked at my ecm, it does not appear to be burned or blown on circuit board. Please help! Thanks Mark. |
| dayle1960 | May 19 2015, 05:34 AM Post #2 |
Did you replace the big yellow fuse underneath the hood, next to the fusebox? Have you tried cleaning every ground within the engine bay? (Including battery terminals?)
Edited by dayle1960, May 19 2015, 05:34 AM.
| freegeo | May 19 2015, 09:04 AM Post #3 |
Which fuse did you replace that blowed? Good chance you have a wiring issue in the circuit. Which pickup did you change? The one inside the distributor? Edited by freegeo, May 19 2015, 09:06 AM.
| crankcase | May 23 2015, 07:37 PM Post #4 |
This does not fit the symptoms exactly, but did you check for a broken timing belt? Look in the oil fill hole while someone cranks. See if there is any movement (cam shaft). |
7:53 PM Jul 10
