Anti - Metro Propaganda
Topic Started: May 31 2015, 09:10 PM (1,601 Views)
I could care less what other people drive, if it's legal then they have every right to drive it.
This is what you said... "People go to pass when the lane splits in two going up hill/mountain I let loose all 415 hp with 800 lbs of torque the turbo winds up with a whistle pushing you into the seat and big grin comes across my face and they look at you in disbelief." This does not describe speeding up because the speed limit increased, it describes speeding up to intentionally keep someone behind you. If that isn't the case, well, that is why it was phrased as a question, not an accusation. I also didn't say you waited until they were about to pass to slam on the brakes, I said you did it when they set up to pass, which is pretty close to what you said, which was "Afterwards some like to get close as possible to your tail to pass at the next chance and I give them a taste of 6 wheels locking up with disc brakes on all wheels hydro boost assisted. Go ahead and slam the back of my truck, there is chunk of iron there in that flat bed and it doesn't give easy, first the radiator will be punctured by the hitch."
So, with the new information you seem to be saying that you are going 5 or 10 mph over the speed limit so other drivers have no reason to pass you, but when they do try you shut them down. Now most drivers would find this annoying and getting closer to get a better jump if a passing lane or break in oncoming traffic happens where it's legal to cross the center line is a fairly likely response. To those that would try it, you state that you lock up 6 wheels to attempt to crash them, well, if they ride your tail anyway. Lastly, you never state you wouldn't leave the scene of the wreck (it's not an accident since it's intentional) but based on your strong response, you apparently would stay to discuss it with law enforcement and render aid to any injured occupants. Now as I said previously, I assume there is a bit of bluster involved in this and more is evident with the implication that I'm trying to pick a fight and one of us will end up banned. I simply wanted to point out that based on your description it was really easy to interpret it as driving like a complete a$$ and give you an opportunity to rephrase your statement in such a way as to not sound quite so bad. So far I would call it a fail, but there is still time and everything is always open to individual interpretation.
Spud
Jun 4 2015, 11:44 PM
Im not going to sit here and play semantics with all details as it is pointless with you. Take it as you want I care even less so now. :screw :kitteh
Edited by Spud, Jun 4 2015, 11:57 PM.
