| Using Automatic Starter in 5 speed?; What is the deal? | |
| Tweet Topic Started: Jun 5 2015, 04:21 PM (586 Views) | |
| cwatkin | Jun 5 2015, 04:21 PM Post #1 |
My starter quit not long ago and I replaced it with one out of a junk car I had crushed. The donor car happened to be an automatic. I understand the starters are different and yes, I found that new replacements have a different part number for each version. I have another spare starter out of a junk 5 speed but this one is installed and works, not that it would be a big deal to swap them. What is the big difference and should I be worried about having this automatic starter in my car? Conor |
| Hotrodray1 | Jun 5 2015, 04:31 PM Post #2 |
Over Educated parts guy
I had one that I did that way years ago. Never had any problem with it. |
| Rondawg | Jun 5 2015, 06:04 PM Post #3 |
I got a spare starter from an automatic. It would be good to know I could use it in my 5 speed someday if needed without worrying about stripping the flywheel teeth or breaking something! |
| Mythstae | Jun 5 2015, 06:07 PM Post #4 |
Metro Starter Options; Which One Do You Need? by Stiffchezze |
| Hotrodray1 | Jun 5 2015, 06:58 PM Post #5 |
the one it shows on that link is for a 1986 chevy sprint auto. I bought one from rock auto a few months back. NIPPONDENSO; Offset Gear Reduction very fast turning over. |
| t3ragtop | Jun 5 2015, 08:30 PM Post #6 |
the offset gear reduction starter is the one i have preferred for years. it will turn the highest compression suzuki g family engine over with authority at 300 rpm. ![]() i used one on the twincam in my red vert. the only caution is that the gear reduction starter used on a twincam requires modification of the rear intake manifold bracing arm. |
| cwatkin | Jun 6 2015, 06:34 PM Post #7 |
Thanks. This is good to know. IT looks like the auto spec starters are beefier than the manual ones so my swap is OK but not always the other way around. I used the spacer plate from my old starter off the 5 speed so guess I am good to go! Conor |
7:53 PM Jul 10
