| Wiper switch | |
| Tweet Topic Started: Jun 15 2015, 08:17 AM (559 Views) | |
| woodman | Jun 15 2015, 08:17 AM Post #1 |
My 97 has only high speed so it stops randomly..not returning to stop position...are these hard to replace, dealing with the air bag etc? Or could the switch be bypassed and just install a universal wiper delay controll switch... |
| freegeo | Jun 15 2015, 10:00 AM Post #2 |
No there are not hard to replace. If you have the right tools. You would need a wheel puller and maybe a couple of special sockets to do it right. You replace the entire unit not just the switch. This link will give you a pretty good idea of what it takes to replace it. http://geometroforum.com/topic/4523993/1/ |
| Metromightymouse | Jun 15 2015, 05:58 PM Post #3 |
Per this thread (and others, this is the first one my search brought up) the wiper switch (arm) is replaceable on it's own. http://geometroforum.com/topic/5333018/1/ |
| woodman | Jul 18 2015, 09:58 AM Post #4 |
Well the other day the slow speed worked perfectly for 2 days.....Then it quit again...Back to working only on high speed.....Is it possible contact cleaner sprayed into the would fix this, ...... Edited by woodman, Jul 18 2015, 10:00 AM.
| myredvert | Jul 18 2015, 10:15 AM Post #5 |
As long as you can live with what you have for a few days, it might be worth a try. That did the trick on my turn signal/headlight bright dim switch... Sprayed contact cleaner in the base the best I could, exercised it for a minute or so, repeated one a day for a few three days. |
2:15 PM Jul 11
