| Heater hose lay out in 94 Metro 3 cly? | |
| Tweet Topic Started: Jun 20 2015, 01:49 PM (464 Views) | |
| Murf 59 | Jun 20 2015, 01:49 PM Post #1 |
Hey guys, I forgot to take a pic of my heater hose layout before I yanked this engine out. The new one is in. It need to know where all of them go again. I think there are 3 hose's. Thanks again in advance. I am held up at this point. Could hear the new engine run when I get this part worked out. |
| Murf 59 | Jun 20 2015, 02:10 PM Post #2 |
| myredvert | Jun 20 2015, 02:27 PM Post #3 |
I went and took pictures of my 91 (standard Emissions), but it may be quicker to describe the routing than go to Photobucket, resize them, and copy them over. Assuming the 94 (standard or upgraded? emissions) are the same... Firewall driver's side fitting to coolant pipe (between the lower radiator hose and water pump). Firewall passenger side fitting to lower intake rear fitting. Lower Intake forward fitting to thermostat housing. Hope this helps. |
| Murf 59 | Jun 20 2015, 03:52 PM Post #4 |
Thanks a lot. Let me go look at it. |
| evmetro | Jun 20 2015, 04:43 PM Post #5 |
The one with the big "U" shape goes on the driver side (to coolant pipe as red vert said). I usually put the U shape downward and slightly inboard. The speedo cable likes to have the U go around it.
Edited by evmetro, Jun 20 2015, 04:46 PM.
| Johnny Mullet | Jun 20 2015, 05:09 PM Post #6 |
One goes in and one goes out. If you mix the them up, don't matter
| Murf 59 | Jun 20 2015, 07:10 PM Post #7 |
Thanks guys. I got it running first time I cranked it over. Is already running nicely. I was getting a CEL. #23 I thought oh What did I up. I did not have the air cleaner hooked up yet. I ran it for a bit, checked the oil and coolant and everything is looking good. I have run it now about 1/2hr. Letting it cool off before I run it some more. In the AM I will put the under body brace back on and take it for a spin. Its pulling 21" of vacuum.
Edited by Murf 59, Jun 20 2015, 07:14 PM.
| David95237 | Jun 20 2015, 08:31 PM Post #8 |
![]() ZetaBoards gives you all the tools to create a successful discussion community. Learn More · Register for Free |
7:39 PM Jul 10
