Hollander wiring interchange '96 3/5 hatchback; engine and dash wiring interchanges with 1996 G10/ 5 speed
Topic Started: Jun 24 2015, 10:49 PM (535 Views)
Tim Keith
Does '97 to '99 engine and under dash wiring interchange with the '96 G10 five speed wiring with '96 ECU ?
Good bye
Probably.
freegeo
As long as both are the same type engine and trans I don't think you should have a problem.
'96-'97 I see no problem. '98 and up may very well be different, it became a Chevy then and some other things changed.
freegeo
As long as it is a 1.0 liter 3 cylinder it should be the same. The 4 cylinders are way different and wont work. I don't have a FSM for anything 98 up so I can't verify that.
t3ragtop
i'm saying no.
the compliment of sensors changed and throttle body's emission and idle stuff varied.
the g13bb cars' wiring definitely doesn't interchange with a 96.
it can be something as simple as an alignment notch on a connector changing from one model year to the next. i know that there were line changes in the map sensors and coolant temp sensors
Mythstae
I have a Suzuki Swift parts catalog, so, grain of salt, as there's nothing 3-cylinder related in there, but...
Well, yikes. I'll just upload the pic to show what I'm talking about. Be just a mo'.
Mythstae
Just look at all the variations, between year, manual or automatic transmission, ABS or no ABS...!
Tim Keith
My 96 G10 five speed has a short that blows the IGN fuse. I removed the engine wiring and unwrapped it, could not find an obvious short. I thought that I'd do the same for the under dash wiring as the car had a jumper wire to the fuze panel.
geogonfa
Just my .02...check the harness that goes under/along the drivers seat... :type
