| 91 geo metro gets shaky when turning on headlights; When at idle it is smooth then i turn on headlights amd it starts rumbling. | |
| Tweet Topic Started: Jul 8 2015, 01:34 PM (364 Views) | |
| Justatickmetro | Jul 8 2015, 01:34 PM Post #1 |
So last night i noticed my car beong extra shaky than usual because ive found out that a have a blown head gasket so that is one reason but i thought it was odd that when i was on neutral the car would shake a lot harder when i turned the headlights on. Anyone else had this happen to them and fugure out what it was? Thanks for any help |
| nineoneandblue | Jul 8 2015, 01:53 PM Post #2 |
Check this............, might help with your idle problem. http://geometroforum.com/topic/4804867/ I would address the blown head gasket FIRST! Edited by nineoneandblue, Jul 8 2015, 02:00 PM.
| myredvert | Jul 8 2015, 06:20 PM Post #3 |
One reason? At this point I would think no other reason is needed or matters.Chasing an idle problem with a blown head gasket seems a bit like urinating while oriented towards the perceptible lateral movement of the air. You may want to get your head gasket repaired asap before you trash your engine. |
| RONNIEREDLINE | Jul 8 2015, 09:19 PM Post #4 |
METRO MAD MAN
in other words what myredvert is trying to say is you might as well piss into the wind or up a rope. hmmmm glad i cleared that up anyway. |
| Stubby79 | Jul 11 2015, 03:14 PM Post #5 |
clean your grounds. And fix your head gasket. BTW, how did you figure out the head gasket was blown? |
2:15 PM Jul 11
