| 2 Connectors left, don't know where they go | |
| Tweet Topic Started: Jul 12 2015, 01:46 PM (957 Views) | |
| Hubcapskater | Jul 12 2015, 01:46 PM Post #1 |
I swapped a 92 for a 94 engine and I have 2 connectors left and I not sure where they go. [url=[URL=http://s356.photobucket.com/user/hubcapskater/media/Electrical%20Connector/image.jpg9_zps5pwsujep.jpg.html] [/URL]]My Webpage[/URL][url=[URL=http://s356.photobucket.com/user/hubcapskater/media/Ground%20wire/image.jpg10_zps6thzitoz.jpg.html] [/URL]]My Webpage[/URL]Edited by Hubcapskater, Jul 12 2015, 01:49 PM.
| ranger88den | Jul 12 2015, 02:47 PM Post #2 |
A/C components maybe? The one with the eyelet is a ground.
Edited by ranger88den, Jul 12 2015, 03:41 PM.
| geogonfa | Jul 12 2015, 02:51 PM Post #3 |
pic #2 looks like a ground wire, mounts under the distributor on the lower distributor housing bolt... ground wire for sure |
| Mothergeo | Jul 12 2015, 03:12 PM Post #4 |
96 geometric manual wire harness ignition connection wire white with thin green stripe wire and has same connector as above where does it go? Stumped?
Edited by Mothergeo, Jul 12 2015, 05:09 PM.
| freegeo | Jul 12 2015, 04:50 PM Post #5 |
In the first picture what is the wire color? Is it a single wire with a clear or white connector end? |
| Mothergeo | Jul 12 2015, 05:14 PM Post #6 |
96 GEO METRO = 3 CYL = WIRE HARNESS COMING FROM FUSE BOX WHERE BATTERY LINES COME OUT FROM, WHITE WIRE WITH THIN DARK GREEN STRIPE AND A CONNECTOR ON IT LIKE ABOVE, WHERE DOES IT GO, CAN'T FIGURE THIS OUT AND ONLY WIRE LEFT TO INSTALL?????? Picture in link --> https://www.facebook.com/media/set/?set=a.866495433385766.1073741828.100000759537697&type=1&l=609f8f1781 Edited by Mothergeo, Jul 12 2015, 05:16 PM.
| freegeo | Jul 12 2015, 06:07 PM Post #7 |
There are 2 white / green stripe wires in that location. Both go to the fuse box. One is the 70 amp battery fuse and it uses that type of end connector, but in your picture it looks like that wire is already there. The other is the 60 amp ignition fuse. check the bottom of the fuse box and see if both of those wires are there. Usually only the ground wires use that type of end connector. That does not look like a ground wire. |
| Mothergeo | Jul 12 2015, 07:54 PM Post #8 |
Yes it's still the main battery wire that comes out of the fuse box. It is a hot wire. Just can't figure out where it connects to. |
| Old Man | Jul 12 2015, 08:02 PM Post #9 |
Start your own thread so we don't get your problems and answers mixed up with this threads original poster!!!!!!!!!!!! |
| freegeo | Jul 12 2015, 08:32 PM Post #10 |
Old man is correct. Please start your own thread so it not confusing to others that may read the original post. We will be happy to help with your problem. Should be a easy fix. |
| Hubcapskater | Jul 12 2015, 09:48 PM Post #11 |
The wire is blue with white stripes |
| freegeo | Jul 12 2015, 11:45 PM Post #12 |
Is it possible that the wire color of the wire is black with a white stripe? If it is that would go to the A/C compressor. Check and see if there is a wire coming from the A/C compressor that is just solid black and is not connected. |
| Hubcapskater | Jul 15 2015, 11:48 PM Post #13 |
It might be black/white and it's very near the a/c. Can't do it till Sat when I get back. I'll post then.
Edited by Hubcapskater, Jul 15 2015, 11:49 PM.
2:15 PM Jul 11
