| Soldering Iron.... suggestions? | |
| Tweet Topic Started: Jul 15 2015, 12:43 PM (1,318 Views) | |
| rmcelwee | Jul 16 2015, 09:11 PM Post #16 |
You better give us a full report! |
| Coche Blanco | Jul 16 2015, 09:59 PM Post #17 |
Give me a project to do... |
| Otey13 | Jul 17 2015, 06:43 PM Post #18 |
Geo Nerd
Look at partsexpress. com |
| Coche Blanco | Jul 18 2015, 11:08 AM Post #19 |
![]() So this is a thing now. |
| geogonfa | Jul 18 2015, 11:22 AM Post #20 |
You can take that short hop to central Texas and help repair a harness hack job that was done by a PO...
| mt999999 | Jul 18 2015, 11:56 AM Post #21 |
Self-Declared "Genious"
Look at this beauty! ![]() Bought this a good while ago... old blow torch with a soldering iron. You can't see the the wooden handle, it's above the picture. I haven't actually tried to use it yet... seals and gaskets are probably bad. Will have to try it sometime soon, see how it goes.
| Coche Blanco | Jul 18 2015, 09:57 PM Post #22 |
So I practiced on some already ruined electronics I had laying around. The point on this iron is no good, because there is very little heat transfer. I have ordered a chisel tip to alleviate that problem. My God does it heat up faster than those crappy pencil ones I'm used to. |
| Silver2K | Jul 18 2015, 11:37 PM Post #23 |
The chisel tip might be OK for removing stuff, but for soldering in a chip, the pencil tip should be OK. You don't want to kill the chip by overheating it. You don't need a lot of heat to get fresh solder to flow. |
2:14 PM Jul 11
