| trouble code po301; need to pass inspectio | |
| Tweet Topic Started: Aug 25 2015, 07:35 PM (411 Views) | |
| metroski55 | Aug 25 2015, 07:35 PM Post #1 |
1996 geo metro LSI 3 cylinder. with a po301 trouble code I changed the 3 spark plugs and wires and distributor cap and rotor. it an good and still runs good , no problems . the spark plugs all where clean with a nice lite burn could have still used them . no noise , no rough idle , still can hit 85 mph no problem just can not get rid of the po301 code any questions just ask it runs good . that is why I have no other things to say about it. |
| David95237 | Aug 25 2015, 07:53 PM Post #2 |
Just how many threads are you going to start on the same problem. |
| freegeo | Aug 26 2015, 01:18 AM Post #3 |
Thought about this code tonight at work. Two things came to mind. Since you have done a tune up on the ignition components the only thing left is a bad cylinder that would need a compression test done to verify that it is bad. A bad signal from crank position sensor due to a damaged ring on the timing gear. Picture with blue arrows. See if this part of the timing gear is damaged. ![]() Has the crank pulley or timing gear had any damage to it that you know of? Do you have your timing cover on the engine? If you do not have the correct tools or ability to do the test do you have a friend or a mechanic that can? |
2:13 PM Jul 11
