Spongy brakes; Replaced caliper Pistons & Seals
Topic Started: Sep 1 2015, 08:42 PM (533 Views)
MPG
I replaced caliper pistons & seals on my 2005 f250 I filled the calipers up with fluid before attaching to brake lines No leaks Brake fluid resevor full Brakes pedal spongy have to pump 2✖️ to get any kind of brakes What's the matter Any advice appreciated. 😃
David95237
You have to do a proper bleed. All the air must be removed from the system.
David95237
Sep 1 2015, 08:51 PM
:gp If its spongy there is air in the system some where.
Here is some reading for you:
https://www.google.com/#q=geometroforum+bleed+brakes
MPG
Sep 2 2015, 10:36 AM
Thankx for the reading 😊. Guess I'll need to buy wife a soda for she'll be my helper 😀
