| rear brakes not holding.; may be proportioning valve | |
| Tweet Topic Started: Sep 23 2015, 07:27 PM (417 Views) | |
| Sir George | Sep 23 2015, 07:27 PM Post #1 |
My helper held the brakes for me to torque the rear wheel lugs to 45 ft lbs. The tires were off the ground. Brakes would not hold tire from turning. The park brake held just fine. I Bled the brakes and even replaced the master cylinder. I put on a used proportioning valve but who knows if it was good? Any ideas as how to get more brake force to the rear? It is a1996 4 door 1.3 5speed sedan metro. |
| Woodie | Sep 24 2015, 04:04 AM Post #2 |
The rear brakes do very little on a Metro. The fact that they last 200K miles proves that. What you're describing sounds extreme, but I've never tried that. I just snug them up then do the torque after the car is back on the ground. Sounds as if you've done a FULL brake job, maybe the shoes aren't settled in yet? |
| Sir George | Sep 24 2015, 07:05 AM Post #3 |
Trouble is, it seemed to have more stopping power before I put new front pads and rear shoes. Before a light pressure on the pedal would slow it pretty good and more pressure would really stop it. It does not have anti lock. Maybe the new pads and shoes are not as good quality. I was wondering if it may have something to do with the rear adjustment parts being worn. Like I said though the park brakes work good. Maybe I just worry about it too much. Thanks. |
| Old Man | Sep 24 2015, 09:48 AM Post #4 |
First thing I would check is if the adjusters are working or not. |
| Sir George | Sep 24 2015, 06:00 PM Post #5 |
I would like to replace the adjusters. Where can I find them? The adjusters offered by Rockauto do not look correct and the local parts stores can't get them. |
| Old Man | Sep 24 2015, 06:04 PM Post #6 |
junkyard? I could never find any new ones for sale |
| Sir George | Sep 24 2015, 07:33 PM Post #7 |
Thanks Old Man. I was afraid that is what I will have to do. I hate to use old brake parts. |
9:49 AM Jul 11
