unlock steering wheel/ ignition lock; 1993 geo metro
Topic Started: Dec 17 2015, 04:14 PM (1,709 Views)
juliusr120
I have a geo metro and the steering wheel locked so I drilled the pin out right in the middle of the X so I will never lock again. and if your key wont turn because of a the turn pin. you jut have to get a screwdriver and push the pin to release it. It will work.
ice
alex smiles
can you go in a little more detail ? please? this has happen to me alot!
If you shut the car off (most cars do this) with the steering turned and there is stress on the steering wheel linkage, the key will not turn unless you grab the steering wheel and move it one way or another the take the load off the lock pin.
ice
alex smiles
i ment where to drill ?
solerpower
ice
Mar 4 2016, 07:45 PM
You will need to take the ignition switch/combo switches off the the steering rack. When you take it off you can tell how the mechanism works. I have never drilled it out, but it feels like there is a spring behind it. The image clearly shows where to drill. I don't recommend the drilling, but to each his own.
juliusr120
you have to drill in the middle of the x to release the steering wheel lock.
