| Lower Front Control Arm; The shaft the control arm slides on what is its name | |
| Tweet Topic Started: May 12 2016, 05:59 PM (451 Views) | |
| winddancer376 | May 12 2016, 05:59 PM Post #1 |
I have replaced the passenger side lower front control arm with no problems. But when I went to replace the drivers side control arm besides busting off one of the 14mm bolts the shaft the sleeve from the control arm slides on is rusted to it. Does anyone know what the name of this piece is and if you can buy a replacement? We don't have heat to remove the sleeve from the shaft. |
| 1DCGUY | May 12 2016, 06:12 PM Post #2 |
Don't be a "Richard"
That sleeve is bonded to the rubber on the new control arm. You will have to get it off before you can install the new one. If you don't have a torch or something to break the rust, you can use a grinder to cut thru it. If you go this route, be very careful, and smooth out any area's that you over grind. |
| Car Nut | May 12 2016, 08:22 PM Post #3 |
7:30 PM Jul 10
