Steering Problem
Topic Started: Jun 23 2016, 06:52 AM (633 Views)
shaft
Is it possible for the steering rack gears on my Metro to get stripped?
When turn my steering wheel (specially on sharp turns like going into a parking space), I can feel and hear a "grind" that seems like the steering rack gear is "skipping a tooth or two". After that when both front wheels are pointed straight ahead, the steering wheel is off center.
Is the rack likely the culprit or is there any other components in the steering system that is worn out?
Sounds like the rack is on it's way out. :'( I'd think twice about driving it until it's fixed. :x Steering is one of the more important things, ya know. :cheers
shaft
Jun 23 2016, 07:30 AM
Thanks SnowFish. I can always count on you.
I would assume a used rack from the JY is probably not a good idea as a replacement.
Whats a good price for a new rack?
I wouldn't be afraid of a junk yard rack. :shake Should be able to "wiggle test" it to see if there's slack or something feels funny. :hmm
I would, however, do new inner & outer tie rod ends. :gamerz
Much easier on the bench than on the car. ^o) Car will need an alignment anyway. :deal Might as well insure everything is solid. :cheers
I think there is a couple of 'universal joints' between the steering wheel and the steering box. Along with that I also believe one of the joints is connected to the shaft with a spline. If all that is true, there is a possibility that the splines are slipping past each other--maybe the locking nut/bolt has become loose?
Just something to check before spending big bucks and/or time for parts not needed.
EDIT:
might also check the steering wheel spline.
Edited by Old Man, Jun 23 2016, 08:53 AM.
shaft
Jun 23 2016, 08:32 AM
Just searched craigslist and found a parts car (95 and 96 model, mine is a '93) and the guy wants $30 for the rack. 95 or 96 rack work on my '93?
Is 30$ a reasonable price if in good shape?
I just replaced the inner and outer rod ends about 5K miles ago.
Edited by shaft, Jun 23 2016, 10:06 AM.
shaft
Jun 23 2016, 08:41 AM
EDIT:
Thank you old man. I will check.
shaft
Jun 23 2016, 10:04 AM
$30 for a decent rack would be a great price! :rocker :rocker However, I'm not sure if the 95 rack is the same as a 93. :hmm Not sure if just the inner tie rod ends are longer, or the whole thing is different. :news
Hopefully someone more 95+ savoy will chime in. :cheers
shaft
I have a feeling the 95+ steering rack will not fit my '93. Rockauto have different part numbers for 95 and 93. My local junkyards has no metros available.
Call all the local parts store and they don't carry it either. Ebay and Amazon has the remanufactured ones but too expensive for me (250-275$).
How about this? http://www.ebay.com/itm/351748337977?item=351748337977&viewitem=&vxp=mtr
Any experience from this seller? Looks like they have a bunch of metro's to part out.
Edited by shaft, Jun 23 2016, 04:11 PM.
don_dowdy
$52 and free shipping from Oregon to North Carolina is a good deal. Considering the shipping on something the length of a rack, he might only end up with $10 or $20. Be careful taking it loose. The bolts tend to break.
I'd take it apart and inspect it closely before spending much money. I doubt it's the rack.
Jun 24 2016, 05:40 AM
:gp :gp
sphenicie
I must cosign here.
Put the front end up on jacks and examine all of the moving parts. Turn the wheel to 'rough spot' and wiggle everything from the steering wheel to each of the wheels.
C V's, Wheel bearings, strut bearings(top of the tower),
Have a helper turn steering wheel while you hold back on the tire, feel for play, roughness, skipping.
if you still can not isolate it, pull the outer tie rod ball joints out of the knuckles and repeat. turn steering wheel all the R then L. This will allow you to look at the R&P with out the other components effecting it.
shaft
Problem solved. It was loose bolt on the top universal joint on the steering column -- it allowed the shaft to rotate when the wheel is turned. Got some locktite on it so all is well.
Thank you all for inputs. Cheers !!!
shaft
Jun 25 2016, 11:22 AM
:congrats Gotta love the free fixes! :rocker
