| Suspension noises | |
| Tweet Topic Started: Jul 5 2016, 10:47 PM (403 Views) | |
| ohiohouston | Jul 5 2016, 10:47 PM Post #1 |
My metro has a couple different suspension noises right now. I get a pretty hard clunk I can feel in my feet when going over speed bumps or entering driveways. And I get a metal on metal rattle when driving on a rough road. Also, my new cv joints are bad after only 6k miles |
| MR1 Kingsbury | Jul 5 2016, 11:46 PM Post #2 |
Exp. builder/rebuilder
Time to evaluate your front struts... They won't normally kill an axle, but the clunking over speed bumps is a dead giveaway. Not too terribly complicated but can be time consuming if you choose to keep the springs. Loaded struts might be the quickest and easiest swap. |
| Car Nut | Jul 6 2016, 03:29 AM Post #3 |
Could be the strut mounts. Could also be your frame horns are rusted out. |
| Scoobs | Jul 6 2016, 09:38 AM Post #4 |
Could be a number of things. Any time i got a clunking noise like what your referencing, it was either one of 2 things or a combination of the pair, Lower control arm ball joint, or the tie rod ends. |
7:30 PM Jul 10
