| lower control arm bushings; bushing replacement | |
| Tweet Topic Started: Jul 22 2016, 09:17 AM (616 Views) | |
| ppena771 | Jul 22 2016, 09:17 AM Post #1 |
hello guys i have a ratling noise under the driver and passenger side .. i was told by the mechanic it was due to bad lower control arm bushings.. in my area dose bushings are a needle in a haystack impossible to find .. was wondering if someone in here has found a similar bushings from a different make or model car dat can fit the metro ..,, THe ball joints are good from both sides so r the tie rods jus changed it like 3 months ago,,,, Edited by ppena771, Jul 22 2016, 09:57 AM.
| geogonfa | Jul 22 2016, 12:48 PM Post #2 |
you didn't say front or rear... but either way Rockauto.com has them...complete with bushings pressed on ULTRA-POWER MS20108 Front Left Lower; Control Arm w/Ball Joint $37.79 ULTRA-POWER MS20107 Front Right Lower; Control Arm w/Ball Joint $37.79
| ppena771 | Jul 22 2016, 01:21 PM Post #3 |
my bad its the front ones i need! tnx |
| ppena771 | Jul 22 2016, 01:33 PM Post #4 |
i only need the bushings for the front lower control arms.. ball joints are good |
| geogonfa | Jul 22 2016, 02:30 PM Post #5 |
Rockauto.com |
| Woodie | Jul 23 2016, 04:01 AM Post #6 |
You can get polyurethane bushings from Whiteline in Australia, but they're going to cost as much a control arms, which come with bushings and ball joint. It's far more labor to replace the bushings and you're going to need a front end alignment either way. Just replace the control arms. |
7:30 PM Jul 10
